Where can I buy performance parts for the 3.2 I have custom intake with k&n and super 40 flowmaster for exhaust and will removing the cats and adding dual exhaust add more power
You could, but those were designed and tested in a lab and provide optimal airflow at the correct temps. You can definitely replace them, but be aware you may hinder performance. You can't just replace it with some stainless steel pipe and expect it to work better. Not to mention your intake get's fairly warm during use (140 degrees on average, if not more). You dont want to use material that absorbs heat easily and doesn't dissipate. Using the wrong material could mean warmer air going into your intake which would also affect performance. There is actually quit a bit of science that goes into designing intakes. More so than people give it credit for. Whatever you decide to do, make sure to post pics so members of the forum can see for themselves.The 2 rubber hoses that go up to the plenum into the throttle. Could they be removed and fabricate my own pipe
