Status
Not open for further replies.
1 - 1 of 1 Posts
· Premium Member
STS Performance:
0-60 mph 6.9 seconds
Top speed 150 mph*
Braking, 70-0 mph 192 ft.
EPA est. MPG 18 city/27 highway**
Max. cruising range 481 miles†
* Requires optional W-rated tires.
† Estimated highway range: Multiply EPA highway estimate by fuel tank capacity.
SLS Performance:
0-60 mph SPN 7.3 seconds
Top speed 112 mph
Braking, 70-0 mph SPN 192 ft.
Max. cruising range 481 miles SPN†
Engine:
4.6L Northstar V8, 32-valve DOHC
STS: 300 hp, 295 ft-lbs torque
SLS: 275 hp, 305 ft-lbs torque
Aluminum block and heads (bore x stroke) 3.66 in. x 3.31 in.
Displacement STS: 279 cu. in.
SLS: 279 cu. in.
Compression 10.0:1
Valvetrain Two-stage chain-driven double overhead camshafts, roller/follower valvetrain, four valves per cylinder
Ignition Crank-triggered individual coil with platinum-tipped plugs
Induction Tuned, sequential-port fuel injection
Max. revs. 6,500
Coolant DEX-COOL, 5 years or 150,000 miles*
Recommended fuel Unleaded regular
* Maintenance needs vary with different uses and driving conditions. See the Owner's Manual for more information.
Driveline:
Brake/Transmission Shift Interlock
Type Front engine, front-wheel drive
Transaxle Electronically controlled 4-speed automatic with overdrive and viscous lock up torque converter clutch
Ratios:
1st: 2.96:1
2nd: 1.63:1
3rd: 1.00:1
4th: 0.68:1
Final drive ratio:
STS 3.71:1
SLS 3.11:1
Chassis & Suspension:
Suspension - STS Fully independent front and rear with magnetic ride control, continuously variable road-sensing suspension.
Suspension - SLS Fully independent front and rear with electronic level control
Dampers, front/rear Electronic
Stabilizer bar dia., front STS 1.18 in. - SLS 1.10 in.
Stabilizer bar dia., rear STS .87 in. - SLS .71 in.
Steering type Rack-and-pinion with Magnasteer® III speed-sensitive variable-assist
Steering ratio 14.8:1
Turns, lock-to-lock 2.4
Turning circle 40.5 ft.
Wheels:
STS STANDARD 7-spoke, 17"x7.5" cast aluminum, chrome finish
SLS STANDARD 7-spoke, 16" x 7" cast aluminum
SLS OPTIONAL 7-spoke, 16" x 7" cast aluminum, chrome finish
Tires:
SLS: P225/60R16 - STS: P235/55HR17
Brakes:
4-wheel disc brakes with anti-lock braking system
Front discs Vented, 11.85 in. x 1.26 in.
Rear discs solid 11.61 in. x .43 in.
Stability Enhancement System StabiliTrak, computer-controlled stability enhancement system
Traction control system:
All-Speed Traction Control
Capacities:
Oil 7 qts.
Coolant 12.5 qts.
Fuel 18.5 gal.
Battery 12 v
Towing SLS - 2000 lbs. - STS - 3000 lbs.
Trunk 15.7 cu. ft.
Curb Weight SLS - 3989 lbs. STS - 4050 lbs.
* Maximum trailer ratings are calculated assuming a base vehicle, except for any option(s) necessary to achieve the rating, plus driver. The weight of other optional equipment passengers and cargo will reduce the maximum trailer weight your vehicle can tow. See your Cadillac dealer for additional details.
Interior Dimensions:
Head room Front: 38.2 in. - Rear: 38.0 in.
Leg room Front: 42.5 in. - Rear: 38.2 in.
Hip room Front: 55.6 in. - Rear: 57.5 in.
Shoulder room Front: 59.1 in. - Rear: 58.0 in.
Interior volume 119.9 cu. ft.
Seating capacity 5 passengers
Exterior Dimensions:
Wheelbase 112.2 in.
Front track 62.7 in.
Rear track 62.4 in.
Length 201 in.
Width 74.7 in.
Height 55.4 in.
Wheel width 7 in.
1 - 1 of 1 Posts
Status
