Status
Not open for further replies.
1 - 1 of 1 Posts
Premium Member
Escalade: (ESV and EXT below)
Engine Type:
AWD - High output 6.0L V8
2WD - 5.3L OHV V8
Fuel Delivery:
AWD - Sequential fuel injection
Displacement:
AWD - 364 / 6.0L (cm3)
2WD - 327 / 5.3L (cm3)
Compression Ratio:
AWD - 10:1
2WD - 9.5:1
Horsepower/Torque (ft-lbs):
AWD - 345 @ 5,200 rpm / 380 @ 4,000 rpm
2WD - 285 @ 5,200 rpm / 325 @ 4,000 rpm
Transmission:
AWD - 4L60-E HD
2WD - 4L60-E
Towing Capacity*:
AWD - 7,800 lbs.
2WD - 7,300 lbs.
Final Drive Ratio:
AWD - 3.73
* Maximum trailer-weight ratings are calculated assuming a standard-equipped base
vehicle plus driver. The weight of optional equipment, passengers, and cargo will
reduce the maximum trailer weight your vehicle can tow. Maximum payload capacity
includes weight of driver, passengers, optional equipment, and cargo. See your
Cadillac dealer for additional details.
Fuel Economy:
EPA Estimated MPG:
AWD - 12 city/16 highway
2WD - 14 city/18 highway
Interior Dimensions:
Head room (f/m/r) 40.7/ 39.4/ 37.4 in.
Hip room (f/m/r) 61.4/ 61.3/ 49.0 in.
Leg room (f/m/r) 41.3/ 38.6/ 27.3 in.
Shoulder room (f/m/r) 65.2/ 65.1/ 64.8 in.
Passenger capacity: Eight (8)
Cargo capacity:
Behind front seats: 104.6 cu. ft.*
Behind 2nd seat 63.6 cu. ft.**
Behind 3rd row seats 10.1"
* 2nd row seats stowed and 3rd row seats removed.
** 3rd row seats removed.
Exterior Dimensions
GVWR:
AWD 7,000 lbs.
2WD 6,800 lbs.
Overall length: 198.9 in.
Curb weight: AWD 5,641 lbs., 2WD 5,407 lbs.
Width: 78.9 in.
Ground clearance: AWD 10.6 in., 2WD 9.7 in.
Height: 74.2 in.
Chassis Dimensions:
Wheelbase 116.0 in.
Tread (f/r) 65 in. /66 in.
Turning Diameter 39.5 ft.
Fuel Tank 26.0 gal.
Escalade ESV: (EXT below)
Engine Type: High output 6.0L V8
Fuel Delivery: Sequential fuel injection
Displacement: 364 / 5.967 (cm3)
Compression Ratio: 10:1
345 @ 5,200 rpm
Transmission: 4L60-E HD
Towing Capacity*: 7,400 lbs.
Final Drive Ratio: 3.73
Fuel Economy:
EPA Estimated MPG: 12 city/16 highway
Head room (f/m/r) 40.7/ 39.0/ 38.6 in.
Hip room (f/m/r) 61.4/ 61.6/ 49.2 in.
Leg room (f/m/r) 41.3/ 39.1/ 37.2 in.
Shoulder room (f/m/r) 65.1/ 65.1/ 64.8 in.
Cargo capacity:
Behind front seats: 131.6 cu. ft.*
Behind 2nd-row seat 90 cu. ft.**
Cargo area length: 98.9 cu. ft.
Exterior Dimensions:
GVWR: 7,200 lbs.
Overall length: 221.4 in.
Curb weight: 5,869 lbs.
Width: 78.9 in.
Ground clearance: 10.7 in.
Height with Luggage Rack: 75.7 in.
Chassis Dimensions:
Wheelbase 130.0 in.
Turning Diameter 43.3 ft.
Fuel Tank 31.0 gal.
Escalade EXT:
Displacement: 364 / 6.0 (cm3)
Fuel Economy:
Head room (f/m/r) 40.7/ 38.6 in.
Hip room (f/m/r) 62.0/ 62.0 in.
Leg room (f/m/r) 41.3/ 38.9 in.
Shoulder room (f/m/r) 65.2/ 65.2 in.
Passenger capacity: Five (8)
Cargo capacity:
Bed height: 25"
Bed length with Midgate(tm) panel Up: 63"
Bed length with Midgate(tm) panel Down: 97.6"
Bed width: 50"
GVWR: 7,000 lbs.
Curb weight: 5,903 lbs.
Width: 79.5 in.
Ground clearance: 10.6 in.
Height: 75.6 in. (includes luggage rack)
Chassis Dimensions:
Wheelbase 130.0 in.
Tread (f/r) 65.2 in. /66 in.
Turning Diameter 43.1 ft.
Fuel Tank 31.0 gal.
1 - 1 of 1 Posts
Status
