CTS 03
Do a search on this forum, I've havent heard of anyone changing it. Are you sure it's the alternator? did you check the battery ? Check for parasitic current drain? It's just so rare that I would check the other things first.
BYW, if you change it, take pictures for the forum.
Sedan de Ville, CTS
BTW, I have found that some GM service mgrs will be happy to do a print out for you, showing you how to R & R parts. Pics and narrative instructions.
Total cost = lunch.
CTS 03
I searched the CTS forum and couldn't find any info on alternator replacement. It must be a reliable item. There was some info on the Catera site which is the same engine but the engine compartment may be built different so the info is not 100% accurate.
CTS
Definately the alternator. Will get pictures for the forum. Not your typical alternator change. 3.2L have it located on lower right. Couldnt find anything on the forum with a search but there will be soon. Thank you everyone that has replied.
