1 - 9 of 9 Posts
Hi,
The latch for the pass-through/ski door on my 2002 Seville is missing, causing the door to flip open whenever the arm rest is opened. From what I read this seems to be a common issue. I have the cover that goes over the spring loaded plastic latch, however the latch itself is gone. For now, I have just inserted a piece of plastic to keep the door locked and while this works fine it also makes door non-functional. I have looked at several websites that sell OEM parts and I couldn't find any that sold the latch.
So, I have a 3D printer and I was hoping to 3D model the latch and print it. However, it's hard to design since I don't know exactly what the original latch looks like. I have these pictures here from user "basscatt's" album: http://www.cadillacforums.com/forums/album.php?albumid=5642
The issue with these pictures are that they are low resolution and only show one side of the latch. I was hoping that someone could take detailed pictures of the latch and possibly some measurements so I can produce the 3D model. If I am successfully able to model a working latch, I will post the .STL file here so others can also print the latch.
Sean
2010 DTS
Welcome :wave:
FWIW, you will not find a latch (or door for that matter). You have to replace the entire unit.
Thanks for that information, I figured they wouldn't sell just the latch. Hopefully I'll be able to print one and if I do hopefully the .STL will be helpful to other members with their latch missing.
Sean
Not "common" in any of the Sevilles I have worked on. Matter of fact, had one with the trunk lever/button for the pass-through missing and we found that in a junkyard. $0.50.
www.car-part.com for the entire door mechanism ??
Sean
pull the back seat out - it could be hiding -
most common was for the spring to pop out -
then the latch would fall down - behind the seat cushion -
That's probably exactly where it ended up, because I found the plastic cover in the armrest well (where it hinges). How does the back seat come out? Do you just pull straight up on it?
Sean
yup -
pull up on each front corner -
lift up and forward -
be careful if you have heated rear seats -
there will be an electrical plug on the passenger side -
If you need to remove the seat back there are 4 spring locks along the top rear edge. Find each one by feel and trip it with a flat blade screwdriver.
^^^Flat head stuck between the seat back and rear shelf. Stick it several inches down and slide it left or right until you hit something. Once you locate a clip, pull the screwdriver up enough to get it on top of the clip, then push down on it while pulling forward on the seat back slightly.
There are also 2 bolts. One at each seat belt anchor location. Easily seen with the seat bottom removed.
Watch out for the release cable for the pass through.
1 - 9 of 9 Posts
