1 - 8 of 8 Posts
2001 Escalade EXT
Ok , Now for the ongoing saga of my Cadillacs front end! Recap! When turning a hard right, I noticed a rumbling/grinding noise, So I replaced the left front wheel bearing and left front axle, I had thought the noise went away, But that was just wishfull thinking, the noise is still there, now I can hear it turning both directions.............IM frustrated as hell, short of changing the right front wheel bearing and axle also I don't know what to do...................any suggestions?
2001 Escalade EXT
Re: 2002 Cadillac Escalade EXT Grinding noise while turning
Well that's the plan, but just a hypothetical scenario here, what else could make the grinding sound up there, Brakes are good.............Could the rackonpinion do that?
03 cadillac escalade
Only other items are cv joint and the differential along with u joints on the front drive shaft that could be a possible cause of the noise
2001 Escalade EXT
Im pretty confident that its not a U-joint..............(bad spelling coming up) could the rackanpinion in the front end make that kind of noise?
2001 Escalade EXT
IM going to do that this afternoon, see if it fix,s the problem, if it does not then im going to have to take it to the shop. And I don't want to do that, I hate not being able to fix something!
1 - 8 of 8 Posts
