1 - 2 of 2 Posts
2002 Eldorado
2002 eldorado... previous owner said it needs recharged after 2 years and I recharged it and it was still hot. Still said low refrigerant even tho the gauge says roughly 44. I need help and if I figure it out I’ll lyk
I refilled my refrigerant and it’s still hot. Hoping to fix it Tuesday
(Moderator EDIT: Post from long-dead thread has been merged into your new thread here. Sub.)
STEP #1 - ALWAYS - check for DTC's - Diagnostic Trouble Codes -
include the DEFINITIONS - and whether the codes are C=Current or H=History -
connect a SET of AC gauges to the refrigerant part of the system -
set the cabin temp to 60* - full cold -
set the blower to a medium speed -
insert a thermometer into the LEFT/CENTER dash vent -
hold the throttle at around 2000 RPM -
close the doors -
post the
ambient air temp -
duct temp -
BOTH the HIGH side pressure AND the LOW side pressure readings -
1 - 2 of 2 Posts
