2002 DTS temp set to 80 degrees. Passenger side works fine with hot air all vents but the drivers side only blows cold air from any left vent, rear vent, and defrost. Any test I can perform.
Yes, pull the DTC's. Look at the B (Body) codes and see if there is one for an actuator.
Use the correct section (JimD) of this link and use the OBD-II link to define any found codes before you post them.
Diagnostic codes read out as a letter, 4 digits, a letter.
P = Powertrain
B = Body
C =Chassis
U = electrical power and data
C = Current - the fault exists now
H = History - the fault has not been detected recently
So, B 0429 C = rear seat console air blend door is faulty
sounds like a failed #1 - LEFT/DRIVER - MIX DOOR actuator -
there should be a DTC pointing to this -
the part you'll need is ACDelco 15-72974 - you can buy it on-line for around $50 -
replacement can be done from up-under the dash - takes less than 90 minutes IF you're agile -
Finally quit raining here and I installed a new Blend Door Actuator. Problem solved, and thanks to all.
