2002 deville
I just recently bought a 2002 cadillac deville dhs with the northstar v8 had 132000 miles I have noticed the car studers when driving but if I turn the cruice control on it stops any idea what it could be ?
2002 deville
Ok I have checked the codes this is what came up
B0429 -temperature control
B1009 -EEPROM checksum error
B1004 -keep alive memory
C1224 -right rear wheel speed sensor input 0
C1228 -right rear excessive wheel speed variation
C0658 -level control compressor circuit high
U1713 -loss of front door module to window motor high speed comm
U1016 -loss of class 2 communication with vcm / loss of communication with pcm
Yes those are the only codes that came up even with the code scanner there was no active or pending codes
did you use the on-board code reader - or a hand-held code reader?
when was the tune-up done?
