1 - 8 of 8 Posts
2002 Cadillac Deville
why do the driver vents blow warmer air than the passenger vents. It doesnt seem possible.
01 Eldo ETC, 02 Deville SOLD!
Is it possible you have the passenger controls adjusted higher or lower? This is a split system, after all..
04 Deville, 11 DTS Premium, 00 Deville (sold), 02 Deville (sold)
Your low on freon... it's one of the well documented quirks of the split zone A/C system in your Deville. When the freon is low the drivers side blows warmer than the passengers side.
2010 DTS
I suppose when you said "why do the driver vents blow warmer air than the passenger vents", I should have asked, how much warmer? The passengers side temp control will only vary the temp about 4 degrees.
2001 DTS
I had the same problem, and I was convinced I had some major problems, but a $7 can of freon took care of it.
1 - 8 of 8 Posts
