1 - 12 of 12 Posts
2002 Deville
I need to identify this connector, in trying to check my transmission fluid I discovered this was disconnected. My baby has been driving horrible like it can’t pick up speed & service transmission message popped up yesterday I’m hoping this is the issue
2002 Deville
Would that cause power loss? Sorry I am not mechanically inclined, Would it cause the Service Transmission message?
I am not sure exactly what effect a bad MAP sensor would cause. It WILL trip the SES light, as it is an emission related sensor, but it WILL NOT trip a service trans message.
Alexandra - 96 SDV Clyde - 15 Silvy
Given the location and appearance of that I would venture a guess that the plug goes to the air ducting for the MAF sensor.
As for the Service Trans Message, sounds like time to get codes pulled.
The 2002 Deville in question uses a 5-pin MAF connector. 2 of those pins are for the integral IAT. (In the picture you're not looking at 2 pins - you're seeing the molded-in locator guides for the male plug) Look up 2002 Deville in Rock Auto - emissions section.
That 2-pin connector in the OP post looks like a MAP connector, but why is it over by the air filter box ?
....... and why the "service transmission" message ?
Isn't there a 2 pin air temp thermistor in the airbox?
RockAuto says it's in the MAF - like my Seville. You have a 2000s Deville there ?
2004 Deville
2004 Deville, Silver, Gone, but not forgotten, 1972 Eldorado, 1974 eldorado, 1975 CDV
Judging from the location of the pigtail, I would say that connector goes into the master cylinder fluid reservoir.The map sensor and tps both have a wider plug.
2005 Deville DTS
jmrf1964 Is correct. It is the male plug for the master cylinder level sensor. It was most likely disconnected to bypass a faulty sensor or a stuck float.
2002 Deville
Discussion Starter #11
Had my mechanic checkout out, he said that it was an extra connector? not sure why its an extra plug
Look to see if the brake fluid level sensor is connected.............pop the hood.
It's on the master cylinder reservoir - in the engine compartment, on the firewall just over where your driver's left toes would point.
The level sensor connector plugs into the black thingy on the side of the translucent reservoir .........
1 - 12 of 12 Posts
