I noticed that the compressor on my 2002 Base DeVille was running quite often, so I assumed that a shock was leaking, just
replaced with Monroe MA822 shocks. The air compressor runs when start up, and if I leave it sit for about 5 minutes the
compressor kick on again for about 7 seconds, if I leave it then again within 5 minutes. Either the new shocks are leaking
or a leak in the line. How can I trouble shoot the air lines for a leak, or could the air compressor itself be leaking some way?
Maybe my old shocks were not leaking and its a line or the compressor? Any suggestions would be appreciated.
Topeka
I have a base 2002 DeVille, the air pump compressor for shocks was running too often, thought is might be a leaking shock,
Just replaced with Monroe MA822 shocks two days ago, the air compressor runs when car is turned on for about 15 seconds,
but it turns on again after 3-4 minutes and runs about 5-6 seconds again, this does this over and over again. The new shocks
should be fine, What would cause the compressor to turn on over and over? If a leak in the air lines, How do I check them out
or could the air compressor be leaking some how? I know that this is not the normal for the compressor to run, must be something
leaking that is causing the compressor to start up again. Any suggestions will be appreciated? Topeka
Topeka
