2001 STS
Hi Guys,
I replace my alternator with AC Delco and before I put everything back, I want to change out the water pump and hoses.
Is there anything special I need to know about the water pump replacement?
I plan on changing out all of the hoses also. Should I use AC Delco or would GOODYEAR brand hoses be appropriate? All the local auto parts stores have GOODYEAR brand.
Thanks for your advice,
2001STSCADDY
Hi Guys,
2001STSCADDY
it takes a special tool to remove it -
I actually prefer Gates hoses -
you could save a substantial amount of money -
by buying everything on-line -
2001 STS
Ranger,
My STS has 185,000 with original WP. I'm replacing WP/hoses since I have everything off and I don't want the WP to go out when I'm traveling and cost me $$$ as well as convenience.
1999 STS - diamond white
Boy I hear ya. I replaced the water-pump housing gasket because it was leaking. Also the belt and pulley. A year later the pump is leaking. It was right in front of me when I did the gasket. :banghead:
The part is cheap enough.
