1 - 2 of 2 Posts
Premium Member
2001 STS
Hi Guys,
I have replaced my rear shocks with the MONROE 822's. Everything went well except the air line. I could not install the air line into the new shock. It seems that the hole in the new shock is too small for the air line. What am I missing? I tried to pull the old air line out to see if I'm missing something but I could not do it. I had to cut the old air line to remove the shock.
Is there a rubber cone or something that inserts into the new air shock?
Thanks,
2001STSCADDY
I install
Re: 2001stscaddy rear shocks
Hi Guys,
Thanks,
2001STSCADDY
I install
the original air line fitting plugs directly onto the Monroe replacement shock -
if you cut something it is screwed up -
Monroe makes a manual-fill kit - AK29 that has the correct ends -
the kit is around $12 -
1 - 2 of 2 Posts
