This is my brothers car that I am working on. 4.6 NorthStar with a Y engine VIN code. It was throwing a p0300 misfire code. I removed both coils and found oil sitting in the spark plug wells of all cylinders, one of which was especially bad. Replaced front and rear valve covers including spark plug well seals, replaced all 8 plugs. Checked the springs in the boots for continuity, cleaned all corrosion off of all electrical components, and lubed all connections with dielectric grease.
All of this made no difference, so checked it out with a better scanner.
At idle, cylinder 3 is apparently misfiring about 180 times per cycle while cylinder 4 is misfiring about 1/10th that rate. At higher rpms (1800ish) cylinder 3 is misfiring 180-200 times per cycle, and there are 0 misfires from other cylinders.
My questions:
1) Is the cylinder 4 misfire likely due to cam-lag from the cylinder 3 misfire, since it is next in the firing order?
2) Is this likely a malfunctioning coil (that is my best guess)?
3) Is cylinder 3 in the rear bank (the black coil nearest the passenger compartment)?
Thanks for your time and advice!
~Roger
My questions:
~Roger
