I need to replace the oxygen sensor in my 01 SLS, and am not a super car guy. Any advice? I've replaced them on Buicks in the past, so I know I can do it, but with this massive Northstar engine packed into such a small space, I do not even know where it is. Can anyone give me some guidance one where it is located and what steps I need to take to get to it? Or is it buried so far in there that I should pay someone to do it. Any advice would be appreciated. Thanks all.
'98 STS (RIP @ 206,xxx miles)
There are (at least) three O2 sensors for your model/year engine; which one are you planning to replace?
And why?
What codes are being set?
Unfortunately, I do no know which code it showed, the guy at AutoZone checked for me. I assumed I'd need to replace all of them (thought there were two, I didn't know there were three). Should I replace all 3 for good measure?
No. Pull the codes yourself. There is a "sticky" in the Tech Tips section that will tell you how to do it.
Go through the archives and search functions in the headers of these pages. O2 sensors are well covered. 1 in the collector of each bank and 1 after cat. Learn how to pull your own codes and find the parts on the recommended sites. If you've done exhaust/sensor work, it's a piece of cake.
Thanks for the info guys. I just got around to pulling the codes this morning. The two current codes are:
PCM P0171
PCM P0174
What I can find on these codes (combined with what I've been reading in other threads) is that it system is running lean. Is this an O2 sensor after all, or do I have a different problem? Any advice would be awesome. Thanks again.
Lean usually indicated a vacuum leak. Since it is both banks I'd check the "plenum". That is the rubber coupler between the TB and the manifold. Seems to be a somewhat common leak point.
