1 - 2 of 2 Posts
2001 Seville STS
This started with the driver's side blend door not working. The actuator was found to be bad and it was replaced. There is an additional problem. The CCU does not operate
the actuator as it should. The actuator can be moved with the Tech II tool hooked up but when the actuator is reconnected to the vehicle harness it won't move.
Does this sound like a bad climate control unit?
Is there a repair service that can check and repair them?
Is there a step-by-step procedure for removing the old unit? I have searched but was unable to find a detailed procedure.
· Master of the Dark Art of Diagnostics
they are VERY reliable - and good used ones are cheap on ebay -
cosmetically worn units are $15 - with free shipping -
yes - you can change the electronics
if yours LOOKS good -
here is a nice one $35 -
http://www.ebay.com/itm/2000-2004-C...001|Model:Seville&hash=item5674b0dde8&vxp=mtr
it takes less than 10 minutes to change the unit -
1 - 2 of 2 Posts
