2001 Seville STS
First, I'm loving this site. I replaced the plenum gasket (thanks to this site) and the iac valve. My car gives no codes and runs wells at highway and street speeds. It's when I come to a stop or barely accelerate when the idle goes up and down and sometimes stalls. Can someone give me some clues to my slow speed, weird idle problem?
2010 DTS
:welcome:
Have you cleaned the TB? If not, you're overdue. If you need help, see the tutorial in the Tech Tips section.
Where are you looking for any Diagnostic Trouble Codes. Use the car's built-in system. The sticky post ^^^ "How to pull codes".
A slow idle and stalls will set DTC's. Not in the normal DIC center warnings and messages - you need to get into the code system's memory to retrieve codes.
2001 Seville STS
I found no codes on the car system and I cleaned the TB when I installed the plenum gasket. However, not sure if I cleaned it well enough. It was dirty when I took it off. I will go back in and throughly clean it this time. Will keep you posted.
