When I start up the car in the morning, the heater is automatically set to 90. Is there a trick to get it to start at like...say 70 er 75...I tried using the set buttons ect on the door panel, but that obviously isnt doing the trick. Thanks in advance.
2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
I think you need to go into personal programming, in the DIC. You should be able to set it there.
Don
Discussion Starter · #4 ·
I'm not sure on what the procedure is.
2010 DTS
After you have all the settings where you want them, press memory set then #1 or #2 (depending on which key fob you use).
Discussion Starter · #6 ·
I tried the set, 1 or set, 2, but after about 15 minutes it goes right back to 90 degrees again.
