My hot/cold air control is wacky. Seems unpredictable, but I'm starting to see a pattern. Won't blow hot air (engine already hot). I mess around with controls turning temp up and then down, switch from foot to face to windshield, then back again. Turn defrost on and off, AC on and off, repeat... Eventually, I get hot air when temp set to 60, or maybe hot from one side and cold on the other. Turn to 90, then the two sides reverse. Set to around 72 and turn up slowly and maybe eventually I will get heat from both sides with temp set to hot. Takes 20 minutes of screwing around but seems to always work eventually.
Had same problem in summer trying to get AC to blow cold on both sides, but definitely seems more finicky in winter.
Thought maybe to change the control unit (one on dash with all the knobs). See them on eBay used. But - also see a "climate control computer"?
Any ideas?
Any ideas?
