1985 Cadillac Seville Elegante
Two days ago or so my brother discovered someone had swiped the two air pump fuses from under the hood, no idea how but they only seem to have taken that and the wheel hub cab center.
In any event the rear air ride seems out of wack as well as the front. The car is now slanted forward in a drag racer style and I have replaced the fuses but the system
hasn't reset. Is there a way to hard reset the air ride system?. I am going to disconnect the battery for five minutes later and reconnect to see what happens but am
stumped. The pumps are working and can be heard so I know they are fine. Car was level before fuses were stolen.
Thanks all as always.
No reset or calibration for ELC (it's not air ride). You'll need to pull your codes. Most likely a bad exhaust solenoid or faulty level sensor.
2000 DTS 194,000 miles, 2000 DHS 203,000 miles
Yea, and I thought the ELC fuse and relay were under the rear seat. Well I know they are on every
Deville I've worked on.
