2001 DHS
my deville was power steering leak, i replacement the Power Steering Pressure Line Hose, and do the balancing, when i drive to 110 km/h or higher the car start jitters. can anybody know the reason. thanks a lot :yup:
These FWD cars are very sensitive to wheel/tire balance and runout. If you can find a Hunter Road Force balancing machine in Beijing, try that. Also, remove the wheels and clean the mounting surfaces, then install the wheels and torque the lug nuts to 100 lb/ft (136 Nm) in a star sequence, working up from 68 Nm.
1973 Cadillac Hearse, 2002 Cadillac DHS
Ditto on Submariner's post. Mine took 2 visits to the tire shop to eliminate the same issue you describe.
