94 Deville 01 Deville DTS
My car has misfire code PO308,my upper radiator hose blew & sent antifreeze everywhere. I replaced the hose & refilled the system. Could the antifreeze blowing everywhere cause the coil pack to short out or cause issues with it.
Certainly. Pull the ICM connector and clean it with electrical contact cleaner and then a shot of WD40.
If that doesn't help you may have to pull the ignition cassette, but I doubt you'll have to go that far.
Pulled the ICM & Ignition cassette & proceeded to clean the ICM & noticed the cassette had a hairline crack around the coil closest to the ICM. I reinstalled & the misfire is still there , so I replaced with a new ICM/coil cassette & all is fine now. Strangely enough, I determined it was the original ignition cassette, as was the upper radiator hose :suspense:.Thanks again Ranger
