1 - 13 of 13 Posts
hi guys i have 2001 cadillac deville limo headgasket blow.can i fit a engine of a 2001 seville sts ?
you can use any Northstar motor from 2000 through 2003 - Deville - Seville - Eldorado -
HOWEVER -
there are TWO different engine codes -
Y = 275hp -
9 = 300hp -
the ONLY physical difference between the two is the INTAKE CAM -
IF your Deville has the CODE Y motor - and you install a CODE 9 motor -
YES - it WILL run OK -
NO - you will NOT get ANY more power - in fact - you MIGHT loose a little gas mileage -
with that said -
you are taking a BIG chance that the replacement motor
MIGHT also develop head gasket problems - or oil leaks - which are equally expensive to fix -
unless the original motor has a LOT of miles on it -
you would be better off getting the head gaskets fixed and the engine completely resealed -
I had this done on my 2003 DHS for around $2500 -
HOWEVER -
Y = 275hp -
9 = 300hp -
with that said -
ok thank you very much
HOWEVER -
Y = 275hp -
9 = 300hp -
with that said -
i am getting the seville engine very cheap only for £300 i am in the uk its very hard to get parts here for these cars. my deville limo is 275hp and the engine of the sts is 300hp do i need to reprogram the ecu? can i use the engine and the transmission of the sts on my deville ?
Yes the tranny will swap, but the final ratios are different.
The PCM will notice this and set a code. No biggie.
No, the PCM doesn't need to be reset.
thanks you very much. so i can just swap the engine and the trans ? or only the engine?
you CAN NOT reprogram the PCM -
and you can NOT use the STS PCM in the Deville -
the final drive ratio IS different -
the Deville is 3.11:1 and the STS is 3.77:1
using the STS trans in the Deville WILL cause some issues -
including constantly setting DTC's Diagnostic Trouble Codes -
and illuminating the SES light -
BUT - YES - it will function -
Discussion Starter #8
thanks for your help.
what is the best to do can i only swap the engine and use the deville trans ?
YES - keeping the Deville trans will eliminate several issues -
HOWEVER -
Y = 275hp -
9 = 300hp -
with that said -
Please hook me up to your mechanic.... I talked to 5 mechanics here in Wisconsin Dells/Madison area... 2 won’t even touch it and the other 3 quoted $4500-5,000 for head gasket replacement and drilling the bolt holes or whatever else they do.
that would be Joe Blau at Midwest Cadillac Repair in Palatine Illinois - 847-776-1234 -
that's only a couple hour drive from Madison -
Joe has done HUNDREDS - could be over a THOUSAND by now -
when you call - tell him you are a member of the Cadillac Forums -
and Basscatt referred you - you'll get a discount -
he does them the RIGHT WAY!
he uses the big - NS300L - "Norms" inserts - NOT the crappy little "timeserts"
he also includes resealing the lower half-case and the oil pan -
I had him replace BOTH front and rear main seals and the oil pressure switch -
AND had him replace the transmission solenoids as a preventative measure -
the entire job was less than $2500 - "out-the-door" -
THANK YOU!! I will get hold of him when things go back to normal.
1 - 13 of 13 Posts
