deville
hi all.i have a deville with a couple of codes and a rela bad mis fire? im tring to figure the misfire and dont know if changeing the cam sensor would do the trick.any info is really gladly appreciated...i had the ecm reflashed i checked wires all looks ok but i have that horrible misfire........help
The CMP sensor needs to be replaced anyway. Change it first and see if it helps.
What wires did you check?
deville
hi ranger thank you for your info i did change cam sensor it helped with quicker starting but it turns out the front coil pack was bad to and its expensive but now shes almost running like a cadillac should thank you for giveing me some info...
