Are you running the stock tire/wheel combination with 30-32 psi as recommended? The OEM setup should give you a Cadillac ride until you push the envelope. Other combinations may well turn your car into an old Morgan recall....
HI, The wheels are OEM 17x7.5 supplied from new. The tires are Bridgestone Turanzas on the rear and Pirelli P6000 on the front running at 30psi.Are you running the stock tire/wheel combination with 30-32 psi as recommended? The OEM setup should give you a Cadillac ride until you push the envelope. Other combinations may well turn your car into an old Morgan recall....
