Wheel hop in a FWD?
Sure it isn't torque steer?
If your air pressure is high (around 35psi or more) the front end on these car can hop a little when the tires brake loose. I ran a 14.809 at Atco Raceway about a month ago. The last run I made, I had 22psi of air in the front tires, and still had traction problems. I know this, because my trap speed was fast enoguh for a 14.7, but my time was slower around 14.849.[email protected] said:What it is is wheelspin.
It just sounds harsh like the front is hopping (which it may be slightly).
How they get 1/4 mile times of 14.8 seconds I will never know as it's so bad...
On some transmissions, line pressure would indeed cause the "shift," but once upon a time I asked our "old friend Bob" and his comment was along the lines of line pressure not being responsible for the shift, but rather the algorhythm in the E-transaxle.danbuc said:Well, technically it is a tiny bit faster, ubt only by a few thousanths of a second at most. This is because the line pressure in the transmission in raised resulting in a quicker and firmer 1-2 shift. Other that that, your still just running through the gears liek you would at WOT in D. You're never going to be able to tell the difference with a stop watch. I would also suggest holding onto the wheel, because the front tires have a tendency to break loose when the car shifts into 2nd gear. It always lets out a loud bark form the tires....usually suprises a few people.
