1 - 16 of 16 Posts
No caddy atm due to HG. 1997 Lexus ES300
I can't find where the flasher goes. I got a new one, and have looked in all the fuse boxes and under the dash on the driver side, no idea.
Any idea where it goes?
I believe it is attached to the 4 way button in the center on the dash.
4-way button? I'm not very knowledgeable when it comes to stuff like this.
Any pictures anywhere. I looked all under the dash on the driver side and didn't see anything.
No, no. Look on the dash, dead center. The emergency (4-way) flasher button with the triangle on it.
Still havn't got around to fixing this. Do I just need to remove the top of the dash above the 4-way to replace it?
According to the FSM, you need to remove the instrument panel upper pad.
You need to remove the right/left windshield pillars. Remove the air outlet deflectors. Close the outlets. Remove the 2 fasteners from inside the air outlet deflector openings to upper pad. Lift pad upward to disengage retainers from the IP cluster trim plate. Remove it.
Hope that helps. If you need further info I can scan this stuff for ya.
Discussion Starter #8
A scan would be great. I'm not used to this kinda stuff. It took 2 seconds to replace the flasher on my old Jeep. lol.
'98 STS (RIP @ 206,xxx miles)
I can't find where the flasher goes. I got a new one....
If you bought an aftermarket 2 or 3 pin flasher unit, it is not going to be a replacement for the hazard/turn signal part in your car. The OEM part connects to the car wiring through a 10 pin connector.
If your 4-way hazards OR any of your turn signals operate properly, I would question the need to replace the flasher unit.
More diagnostic troubleshooting is indicated here.
Discussion Starter #10
I got a 3pin one from autozone. They said it would work, not sure. Hmm.
All of the lights turn on, but do not flash. They will occasionally decide to flash, slower than normal though.
....All of the lights turn on, but do not flash. They will occasionally decide to flash, slower than normal though.
If it was my car, I would spend some time investigating corroded/burned/damaged lamp sockets and bulbs starting with the rear lamps.
Discussion Starter #12
But they all worked and then all of a sudden they all stopped flashing.
OK. I get it; the symptoms are obvious.
Now all you have to do is find out "why" that happened.
And a failed flasher unit is the least likely "why".
I have a spare flasher. It was for my daughters '04 Grand Am, but might be the same part. GM part no. is 1035-9039. Let me know if it is the same part. I think http://www.acdelco.com has a part interchangeability search.
Discussion Starter #15
Any luck with the scans?
1 - 16 of 16 Posts
