I'm fairly confident and patient with electrical wiring. I can obtain all the Bose components, wiring pigtails,etc. for around $50 from a "u-pull" salvage yard, so cost isn't an issue. My parents had a new sts in 2000 with the Bose system and I loved it. I'm not into big bass, or any of those things. The Bose system is probably the highest quality mobile system I've experienced. Do any of you know what has to be re-wired? Is the wire anything special?
if you are REALLY SERIOUS about this project -
you need to pick up some supplies before you start -
a box of gallon size FREEZER zip lock type bags -
a box of quart size FREEZER zip lock type bags -
freezer bags are a lot thicker and stronger than storage bags -
a couple sharpie brand markers -
they are permanent ink markers that won't run/smear -
roll of 1" wide masking tape to label stuff -
just take your time removing - and SAVING - AND LABELING - EVERYTHING -
and I do mean
EVERYTHING -
from the donor car -
save every plug - every wire -
connected to every component -
and LABEL IT -
label every ground -
and take a pic of where it was -
CAREFULLY remove the ENTIRE wire loom -
all the way back to the fuse box -
and LABEL IT -
because it will NOT be in your car -
save EVERY nut - bolt - screw - and BRACKET -
that's what the zip lock bags are for -
AND LABEL THE BAG -
also get a steno pad- and take COPIOUS notes -
about each part - where it came from etc -
take LOTS of pics - showing location of parts -
remember - DO NOT CUT A SINGLE WIRE -
unplug each connection -
and carefully remove each and every wire loom -
you need EVERT SINGLE PART of that BOSE system
if you expect it to work in your car -
GOOD LUCK - and keep us posted - :highfive:
