1 - 9 of 9 Posts
Bait and switch??
You go there, find the part, and if it's in good condition you buy it. Not sure where the bait and switch would come in.
'02 Eldorado ETC 85k miles / Past: '03 Deville; '02 STS
☝☝Except in my part of the country, there's maybe ONE salvage yard with ONE Eldorado, and it's usually a late 80's model...
98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
What's wrong with yours? The material coming off?
If the material is separating from the shell, easy fix.
1999 Eldorado
Discussion Starter · #7 ·
98eldo32v, the plastic is cracked in three spots... in addition to all 3 fasteners being broken.
cabbage, i call before i go down there, a lot of times they'll say they have the part, you go down there and they don't .. then they try to sell you something else
Find another set of pillars in ANY color, remove staples at ends of covers.
Peel off material.
Go to upholstery shop find material and color that matches the closest.
Cut material to shape of old removed material.
Use 3m Heavy Duty trim adhesive, spray on back of material, apply coated material to pillar housings/shell.
Let dry, re staple ends of material back on to shells/housings.
Re install pillar moldings....
1 - 9 of 9 Posts
