SpeedinBitch said:
No lights are staying on. But now I am having a new issue arise. When I roll up or down my windows the lights flicker so now I'm thinking there might be a short somewhere. And just this evening when I went to start my truck the clock was set at the wrong time. I am hoping that its not a computer issue if that's the case I might as well invest in another Cadi :\
Sounds like the bcm connections it is under the dash next to the steering column if the connections ain't the case then most likely the bcm is starting to fail(which clock are you talking about if its the one on the radio then I see the relation)
Also even if you replace the bcm its still cheaper then another truck
Here is a parts site
www.rockauto.com
Of course this can be a loose or bad ground so check every possibility before making a expensive decision like this
(Ps my radio went black on me tonight as I was driving but I think it's because of my media gateway)
