2000 eldorado
2000 Eldorado with water leak about mid interior firewall, need help please
Hi all, some time ago I bought this car with water damage. since that time I've tore the carpet seats and headliner out. checked all 4 drain tubes on sunroof and found 2 to be clogged, all 4 now fine and cleaned.
I thought I was ready to install the new carpet BUT after a water test I see a trickle of water on the floor pan, I looked up and I can see it is coming from behind insulated firewall matting, I felt behind and its wet. so I dried it up and again I sprayed in front cow panel, by the way cow panel cover is off, I thought i would remove it and see tons of leaves or whatever causing blockage but nothing BUT when i spray into that cow area it runs thru firewall somewhere???any ideas of what this might be from?
thanks for help and or ideas....
2000 eldorado
Where would that be located? Also I was just water testing when I saw leak from up under dash, I was spraying around cow panel. Can you let me know where to look for that drain please... thanks
Car up on a hoist. A/C sump drain is a rubber elbow sticking out of the firewall at about the turn to the body pan, just passenger side of center, about under where a front seat passenger's left heel would lie.
Rod it out with a fuzzy pipe cleaner - craft stores.
Excess water into the cowl grille might well run down the intake ducting and wind up in the A/C drain sump.
