1 - 13 of 13 Posts
B codes
2710
2750
1160
1163
0856
1552
1558
1972
2472
2476
2120
C Codes
1234
1277
1298
P codes 1644
U Codes
1040
1064
1088
1096
1016
1000
1301
1153
1255
Symptoms are gear selector flashes ,air bag light ,track light , theft car may not start , temp is pegged cold , window don’t work intermediate, battery light , climate control goes black goes on at random , no singnals no high beams , etc symptoms are not always there intermediating help much appreciated
B codes
2710
2750
1160
1163
0856
1552
1558
1972
2472
2476
2120
C Codes
1234
1277
1298
P codes 1644
U Codes
1040
1064
1088
1096
1016
1000
1301
1153
1255
codes are meaningless without their DEFINITIONS -
there are THOUSANDS - and no one has them all memorized -
go here for the best list of Cadillac code definitions -
also include whether the codes are C-Current or H-History -
some history of this car might be helpful -
everything happened at the same time?
car sat for a long time?
flood damage?
accidents?
stolen recovery?
just got the car?
flood damage?
accidents?
stolen recovery?
just got the car?
It’s a convertible coach builders low mileage car sat few months just picked it last month thanks for the help
Discussion Starter #6 (Edited by Moderator)
again -
Thank you again I’m looking them up but I’m no mechanic or electrician so I don’t know what they mean
Current codes
u1301 - class 2 short to battery
U1096 - Loss of Communications with IPC
U1016 - Loss of Communications with PCM
well - IF you don't feel qualified to work on these issues yourself -
you'll either be on a REAL QUICK learning curve in AUTO REPAIR 101 -
OR you'll be paying a qualified mechanic around $100/hr to track down the problems -
YES - we can offer some help and guidance -
but YOU must have the willingness and a few tools -
Discussion Starter #8
I’m willing to learn I’m gonna try cleaning the terminals the alternator seems to be fine it’s running at 13.8 I’m posting here to be pointed in the right direction
electrical problems on a 20 year old - HIGHLY modified Cadillac - can be a real challenge -
even for ACE mechanic -
Discussion Starter #10
Ya I hate to throw parts at it but I’m gonna do the vats bypass and my buddy has a bcm
throwing parts at it - and HOPING something sticks
is the WORST - and MOST expensive - "solution" to fixing a car -
WHY?
look at the CURRENT codes and their definitions -
THOSE are the problems -
says nothing about VATs -
as for the BCM -
get a spray can of ELECTRICAL CONTACT CLEANER -
pull the connectors apart - flush out BOTH ends -
then carefully inspect each connecting pin for evidence of dirt/corrosion -
Discussion Starter #12
WHY?
as for the BCM -
B2750 is a vats code
OK - BUT - it is a HISTORY code - meaning it WAS a problem at some time in the past -
BUT - it hasn't happened again - and is NOT a problem today -
1 - 13 of 13 Posts
