1 - 9 of 9 Posts
Recently had my AC compressor replaced. When I got the car back the AC was working, but the performance was very poor relative to how it had worked previous to its going out. The second day I had it I was driving and got the code B1347 and the message "Low refrigerant - A/C off". I took it back to the guy who did the compressor and we hooked up the gauges to add freon but it showed a full charge. We reset the code and everything seemed to work (again at the lower performance level). The next day I started getting code P0533 AC pressure sensor circuit High Voltage and 2 days later (today) Im driving and again get B1347 and the message "Low refrigerant - A/C off" and the compressor shuts off again.
I know zip about AC systems. Can a bad pressure sensor be causing all these problems? If not, what should I look into? And if so, where do I find it and what's involved in changing out that sensor?
Its 102 in Texas today. This is close to the top of my priority list.
Thanks,
tqp
2010 DTS
You had A/C work done and it is not working properly. You don't need to know anything about A/C. Take it back.
Generally speaking what you say is true.
However, my confidence in the ability of the person who did the work is, at this point, lets say limited. I'll be a lot more confident of having it completely and properly fixed if I understand the problem and can supervise the repairs myself. I don't want to have to take it back 2 or 3 more times until this guy gets it right.
It's too hot to piecemeal this repair.
tqp
1997 Eldorado
check your sensors. my refrigerant sensor went out and i got the low freon message too. also would not allow the compressor to cut on. check all the sensors first.
2010 DTS
I am not sure what sensor that P0533 is referring to. I am also surprised that it is a P (PCM) code and not a B (body) code.
1997 Eldorado
P0533 - Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit High Voltage
might be the same sensor as mine? i too would get "Low refrigerant - A/C off" when i was full pull it out and put a jumper into it. if the code changes or a new code pops up it might be your issue.
check this out might help
http://www.ls2.com/boggs/dtcs/DTC P0530.htm
2000 ETC
I don't mean to 'jack the thread, but I also have a 2k Eldo with an AC issue (I'm pretty sure). Recently the SES light has been setting. After clearing the PCM codes a few times the only current code that keeps coming up is a P1545 (AC clutch relay control circuit) (besides a lumbar sensor code B2119). Will that set the SES? For some reason I seem to recall seeing a current P1545 some time back and it wasn't firing the light.
2010 DTS
Only an emission code will trip the SES light. I would not consider P1545 (AC clutch relay control circuit) an emission code.
1 - 9 of 9 Posts
