None
My Cadillac 2000 deville works fine in tell you hit a big hill hear in Mt there are many I put a thermalstat in it worked fine on The way home it started getting hot up the hill that I just went 80 up with no problems I'm going to Get A Rad Flush AND
Hope it don't do it any more if it was a head gasket it would overheat every time right
_______________________________________________________________
Good evening, Your CF account is activated. Welcome aboard !!!!
Please update your profile to show correct information and time zone.
Please do not dredge up old threads, dead for over 5 years. Post your own thread with your own problem.
You NEED to do some homework in the Deville, Seville, Engines; Northstar and Cadillac Tech Tips forums for insight into the engine cooling system, gauge, and fan operations. You probably did not need a new thermostat in the first place.
One of the early symptoms of the head gasket failure is getting hot under load. I suggest to start with the block test.
:yeah: Yup, you have early symptoms. Follow Maeng's advice.
P.S.
:welcome:
2001 Deville DTS
It doesn't mean it will do it everytime. I have failing headbolts and things such as the outside temp can affect whether it does it on a hill or not.
