Cadillac Deville 2000 base
Low oil pressure light just came on. Stopped the car, then restarted, oil pressure light went out. Any idea why that happened? Going on a trip in a few days so I hope it's not a problem. Any input is greatly apprectiated.
2000+ seem to be prone to an oil pressure sender failure which manifests itself at hot idle.
The ONLY real, true way to confirm oil pressures is to hook up a mechanical gauge to the oil sender port, and that involves a mess and chassis hoist plus time, tools, and a gauge and proper hosing.
Oil level OK at halfway up the dipstick hashmark, 5W-30 ??
DO NOT dump in some "heavy oil" or magic oil potion: find the real problem.
:yeah:
I'd just replace the switch (only use an A/C Delco switch ).
Ranger, replace the oil pressure indicator switch?
Submariner409, the oil is half way up the hash marks and yes I use 5w-30.
BTW, it has not done it again. But only drove a few miles.
Yes, the oil pressure switch on the oil filter adapter (if the problem persists).
