My dad just bought a 2000 Deville from a friend of his and found out that it is leaking transmission fluid. I'm looking into this for him to see if I can find out anything so if you need any more information I can ask him.
On start up it leaks about 4 fluid ounces from the drivers side while sitting in the driveway and then a little more when you reverse out to leave. Once the car is going it appears to stop leaking. He can find where it is leaking from so that he can fix it himself. The Cadillac dealer where he lives estimates $1500-2000 to fix it. The car runs and drives great but he really wants to get this fixed himself without having to pay a dealer to do a simple fix for him. Has anyone else had a similar problem to this and know where the fluid could possibly be leaking from? Any help would be greatly appreciated!
As I said, I just talked to him on the phone about this so if you need more information just let me know and I will ask him. Thanks!
2010 DTS
You will need to pin point the leak a little better than "The drivers side". Could be a trans fluid fitting at the radiator side tank (trans cooler) if it is that far up front. If it is farther back, it might be the other end of those lines, side case seal, pan gasket.
