1 - 10 of 10 Posts
2000 Cadillac Deville DTS
my DTS between 60-70 mph starts to shake a bit and when i use my brakes around that speed shakes even worse. Also when i first take off from a stop it shakes a little bit but not that much. On the freeway when it shakes so does the steering wheel. Anyone have any idea whats going on? i would appreciate it
worn hub/bearing -
worn suspension parts -
worn steering parts -
out of balance tires -
bent wheels -
bad tires -
build-up of brake material on brake rotors -
2005 CTS/ 2008 DTS/ 2008 STS V8 N*/ 2011 CTS4 ALL W/D Pearl
I would first get you're tires Road Forced Balanced, our cars a very finicky about tires and balancing. If that doesn't fix it, you're probably looking at new wheel hubs. Don't forget the easy 12-6 oclock wheel check. It costs nothing and it will tell you about you're hubs, should be no play.
Raise the front wheels off of the ground, grab the tires at 12 O clock and 6 O clock, and rock the wheel back and forth.
^^^ What MC said ...........
Perceptible tire/wheel in/out movement at 12 - 6 is hub bearing slop. Movement at 9 - 3 is tie rod and/or suspension wear.
^^^ Not always, but a necessary yes/no test.
1 - 10 of 10 Posts
