1 - 18 of 18 Posts
2000 deville dhs
hi everybody my 2000 deville water pump was bad I replaced it and my coolant tank now im getting the check coolant level sign and my coolant level is fine do anyone know why that message keep coming on can the new coolant tank be bad
Re: 2000 caddy deville coolan lights on
it is possible - what tank did you get - where did you get it?
check for codes -
don't forget to post the http://www.amazon.com/gp/product/B003S5XCDQ/?ie=UTF8&me=ATVPDKIKX0DERDEFINITIONS -
along with the code numbers -
98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
How long ago you replaced the pump and tank?
2000 deville dhs
the pump I replaced last month and the tank yesterday and I didn't see no codes
codes do not appear by themselves -
codes must be "pulled" -
Is the coolant level sensor plugged in ?
2000 deville dhs
i pulled my codes an there are none and everything is plugged in I got the tank off ebay
2000 deville dhs
Discussion Starter #8
today I checked my plug to the coolant tank I don't think its getting power in it do anyone know how to fix this problem
2003 Deville Base
Are you checking coolant level with engine hot or cold?
2010 DTS
Exactly where is your coolant level? You don't have to be too far below half for the message to pop up. Put the coolant level at about 2/3 and see if that helps.
It sounds crazy but it takes some time to get all the air out of the system to get rid of the low coolant message.
I suggest waiting till the car is dead overnight cold, The next start up remove surge tank cap, turn heater on highest temp setting and let run fro about 10-15 in drive way. Shut off and let it cool down again. While it's cooling down the tank coolant level may get low, this is a good time to add coolant. You may have to repeat this maybe twice.
Good luck
2010 DTS
Yeah I forgot about that. You may have to top it off 2 or 3 times til it purges all the air. That's normal.
2000 deville dhs
Discussion Starter #16
im gonna try that in the am also I put a light tester on the wire and it didn't light up should the wires be hot
2001 Deville DTS
Hey I am having the exact same problem, replaced my tank with a new one from rock auto and still get the check coolant level when the level is good.
I cut a new plug of a doner car today and splice it in to the existing wiring and ground the black wire to the body to see if that works?
1 - 18 of 18 Posts
