During heavy acceleration or speeds around 80+ the A/C pump shuts down until loads or speed is reduced. Then it returns to normal.
03 Escalade, 06 SRX
Welcome to the forums. I moved your thread to the Deville section from the lounge. The lounge is for off topic discussion or to stop by and introduce yourself to other members here. Good luck.
03 DTS
Most likely needs a can of 134A added to the system. There is a low suction pressure cut out switch on the AC and the faster the engine runs the lower the suction presasure goes. If the system is a little low it can cut out under higher RPM's.
You don't need to add anything. The PCM disengages the compressor under WOT on the assumption that you want maximum power. It's normal.
