We charged the A/C system in our Deville, and everything worked fine for a couple of days. Then it quit blowing cold air, the pressure was way high in the system and the compressor is not turning on. Any ideas?!!
let me guess -
you are using a mickeymouse "gauge-on-a-can" with the three colors - green - yellow - red - and NOT a real AC gauge set - correct?
that single "gauge" is only connected to the LOW side pressure -
when the compressor is running
the LOW side pressure gauge shows the LOW side pressure reading -
which is typically in the 35 to 45 psi range -
and the HIGH side gauge shows the HIGH side pressure reading -
which is typically in the 250 to 400 psi range -
when the compressor is NOT running
the entire refrigerant system equalizes out -
and BOTH the LOW side gauge and HIGH side gauges
will display the SAME - STATIC pressure - typically around 115 psi -
SO - what this means is that your system is NOT over-pressured -
it is just showing the STATIC pressure of your system -
the fact is that your system is probably LOW on refrigerant
which is why the compressor won't engage -
