2.0T bad pistons - roll call & build dates
316K views 696 replies 184 participants last post by  pulaskitrio
Could all you guys who have seen bad pistons or blown motors on the 2.0T please post to this thread along with your build date? It would be interesting to know if you are/were tuned, but I don't think that info necessarily needs to be shared (especially if you are concerned about "privacy").
There are a lot of assertions what GM did or did not do and when. Let's try to generate some facts! GM is not sharing their data yet, but I think this community is large enough where we can start compiling some data of our own.
Who wants to go first?
#78 ·
Service Bulletin: PI-1178
NHTSA Number: 10055103
Service Bulletin Number: 370335
Posted Feb 1 2014
Text:
"GM: THE ENGINE MAY RUN ROUGH WITH THE CHECK ENGINE LIGHT ON/LOW COMPRESSION ON CYLINDER MISFIRE. STORED DTC P0300. THIS MAY BE DUE TO A PISTON IN THE CYLINDER CRACKED BETWEEN THE PISTON COMPRESSION RINGS. *JS"
The TSB is only applied to 2013 ATSs and 2013 Malibus. But there *are* 2014 ATSs and CTSs on these very forums with blown pistons due to this issue, so the TSB is not the "be all end all" or "smoking gun" we're hoping for (and why this isn't a 'bad batch' issue but a design problem).
FWIW the TSB number is posted by smurfkiller on the first page of the thread :)
#85 ·
Does anyone know when the ATS's started rolling off the assembly line? Not trying to hijack thread I don't want to start a thread on something so small. Mine was 8/12 and now I feel like my car isn't new anymore. It's now going on 2015.
I found it. 7/27/12 as it says on google. I knew my car was early but not that early in production.
#87 · (Edited)
I also believe if you want the day it was built (completed) it's on a sticker under the cup holder of the center console. Not sure how to pull the cup holder out? You can also ask your SA he can look it up by your VIN and give you a day. I PMd my VIN to RippyPartsDept (Chris/member) and he looked mine up for me 12/21/2012 just before Christmas, my sticker on the pillar just shows 12/12.
#93 ·
Found a few more from this and other threads not on the list yet. Tried to put it into columns to show things more clearly, not sure the formatting will be any good but here goes...
# name mileage year/model built piston(s) engine repaired/replaced
1. smurfkiller 4700 2014 ATS ??/?? #3 replaced
2. 400hpATS 4213 2013 ATS ??/?? #3 warranty would not cover, building aftermarket 800+hp engine
3. caleb bennett ???? 2014 ATS ??/?? #4 repaired
4. byrce2.0t 15000 2013 ATS ??/?? #1&4 repaired
5. shortfur7 5200 2014 ATS ??/?? #3&4 repaired
6. soop3rn0t 6800 2014 ATS 07/13 #4 repaired
7. calicts 9000 ???? CTS ??/?? #1 repaired
8. romanats 20000 2013 ATS ??/?? #3 replaced
9. ElanX 3700? 2014 ATS ??/?? ? repaired (from the other thread this looks like it was injector failed and blew a hole in the piston, maybe not the same type of failure?)
10. Shooter2384 ???? 2014 ATS ??/?? ? repaired
11. chrisgarner ???? 2014 ATS ??/?? ? replaced
12. Skenny50 6000 ???? ATS ??/?? #4 replaced
13. DB_Outlaw 12000 ???? ATS ??/?? #1 repaired, he sold car then new owner possibly had to have engine replacement
14. Firepower ATS 9000 2014 CTS 09/13 #1 repaired
15. TheRival 5500 2014 ATS ??/?? #4 replaced
16. parker133t 17000 2013 ATS ??/?? #4 repaired
17. pnm215 20000 2013 ATS ??/?? ? repaired
18. SmurfettesCaddy 16000 2013 ATS ??/?? ? repaired?
19. lemons1843 22000 2013 ATS ??/?? ? repaired?
20. LChris24 40000 2013 ATS ??/?? ? ?
#98 ·
My bizzare episode included NO CEL light, NO codes stored, and dealer denial, until I had to twist some arms and then they found 78 psi in cylinder #1., seems a bit peculiar to me...more like a cover up. My ATS did the same thing, and dealer brushed it away, I got rid of the ATS in favor of the CTS so I never got to confim a bad engine, but now I am 1000% sure my ATS had a blown motor too..
#100 ·
SC2150 makes a valid argument for his hydrolock theory. I considered his point of view with skepticism because his theory and solution support the sale of his products. However, I think there is additional evidence to support the theory that condensed liquids in the intercooler are being ingested.
One forum member mentioned leaving his dealership and then making what I understood to be a spirited u-turn just before engine failure. It’s then possible that accumulated liquid sloshed to the exit side of the intercooler (assuming it was a left-handed u-turn) and was picked up by the air stream.
I haven’t seen the bottom of my intercooler to know whether its shape is conducive to this fluid flow. Maybe SC2150 and others can say whether this is evidence or coincidence.
#101 ·
No offense to SC2150 or anyone else - but this isn't just a simple question of a slug of liquid getting into the chamber. Or a function of the ATS's intercooler. Or the piston squirters. Or the fact that the pistons aren't forged. Or the fact that the engine is direct injected. It's a combination of a LOT of factors that creates a 'perfect storm' for the LTG. A meth kit may help. A catch can may help. Forged pistons may help. A different piston and ringland design may help. Drains in the intercooler may help. But there's no definitive guaranteed fix, because there's no one thing that is causing it.
Further, we don't see failures like this on the Regal and Malibu, and when you compare the ATS's cooling module to the CTS to the Regal to the Malibu, it's not just a simple "ah yes liquid builds up in the intercooler because the ATS's and CTS's are more efficient", because not only is their capacity not that different, but driving conditions and whether or not the engine has reached operating temperature plays a bigger role than the differences between these 4 vehicles.
Really, the only potential "AHA!" moment for the LTG failures and why they are seen in the ATS and CTS vs the Regal and Malibu is the engine being transverse or longitudinal... And that's not the issue either.
But there are LTGs with blown pistons where the intercooler and intake tract were clean and oil free, and they had the same ringland issue. There are also undoubtedly LTGs running around with an intercooler that has a giant puddle in it and oil coating the intake manifold and deposits on the valves up to oblivion and they're running just fine.
Forged pistons, a meth kit, and a catch can (I'd wager) would be a great start - but again - there's no guaranteed fix yet because we still don't know 100% what the root cause is.
#102 ·
Appreaciate the reply, and I have not had any Malibu's or Regals in to see. roadpie, are you tearing these actual engines down and examining like we are? What we are seeing has nothing to do with the oil squirters...they do an excellent job in cooling the pistons from the bottom side, and oil squirters are in millions of engines on the road for years w/no issues. Have you seen those intercoolers personally to verify no liquid in the intercoolers? I also agree with you that engine orientation should have no effect as well. This is why I am looking to discuss these failure with others that do work on them and if they actually are removing and draining the intercoolers. Most to date I have talked to never removed the intercooler, they just dropped engines out and replaced or replaced piston/rod assy.
What we are seeing EVERY case to date, is this liquid in the intercoolers, intake charge pipes, and pooled in the bottom of the intake manifolds:
No forged piston could compress this either...it is physically impossible. Only a very tiny amount of liquid can pass through the compression process, and this amount were draining from the intercoolers is extreme. We don't know if the regal is experiencing this yet as we don't get Buicks in here to see....but we do build a good number of Cadillacs, and this is what we are basing this on seeing it first hand (same with the Ford Ecoboost, and the only thing they share is a poorly and flawed PCV system design that allows this to build up in the crankcase and further in the intercooler):
NTSB safety agency to investigate Ford pickup engine trouble
NEW YORK TIMES NEWS SERVICE
Share0 Tweet0
0 Reddit0 0 Email0
The NTSB decided to investigate after receiving 95 complaints from F-150 owners saying they had experienced unexpected power loss during hard accelerations. The NTSB decided to investigate after receiving 95 complaints from F-150 owners saying they had experienced unexpected power loss during hard accelerations.
THE BLADE Enlarge | Buy This Photo
The National Highway Traffic Safety Administration said Sunday that it was investigating consumer complaints about “sharp reductions” in acceleration on 2011 to 2013 Ford F-150 pickups that are equipped with the 3.5-liter EcoBoost V-6 engine.
The action, called a preliminary evaluation, covers about 400,000 of the F-150 pickups, the safety agency said. A Ford spokesman, Michael Levine ,wrote in an email that although the number of vehicles affected was likely to be more than 325,000, the agency’s figure was too high.
The F-150 is one of the automaker’s most popular, lucrative and thus important vehicles. And the twin-turbocharged EcoBoost V-6 is one of Ford’s main engines, used to power not just the F-150 but also sport utility vehicles like the Explorer, crossovers like the Flex and cars such as the Taurus.
A Ford spokeswoman, Kelli Felker, wrote in an email that the company was aware of the investigation and will cooperate with the safety agency.
The safety agency decided to investigate after receiving 95 complaints from F-150 owners saying they had experienced unexpected power loss during hard accelerations. About one-third of those complaints said the problem had occurred in damp or rainy conditions. There were no reports of accidents.
“Attempting to pass a vehicle accelerating from 55 miles per hour and truck either stutters or stalls,” one owner wrote to the agency in February 2012. “This almost caused a head-on collision. I am scared to pull out in traffic or pass anyone.”
The safety agency said Ford had sent three technical service bulletins to dealers telling them how to cope with “intermittent/stumble misfire on acceleration” in humid or damp conditions.
The EcoBoost is a family of engines in various sizes. Ford has widely promoted the EcoBoost’s turbocharging and direct-injection technology as providing excellent power as well as fuel economy.
The investigation covers only the 3.5 liter V-6, which made its debut in the F-150 for the 2011 model year. In 2012, about 43 percent of the F-150s were equipped with the optional 3.5 liter engine, Levine wrote in an email.
If investigators find additional reason for concern during the preliminary evaluation, it would be upgraded to an engineering analysis.
A preliminary evaluation does not typically result in a recall. That outcome is more likely — but not certain — with an engineering analysis.
Last July, Ford recalled about 11,500 of its 2013 Escape crossovers because of a fire hazard with its 1.6 liter EcoBoost four-cylinder engine.
Read more at http://www.ourtownperrysburg.com/Au...afety-agency-to-investigate-Ford-pickup-engine-trouble.html#HB4WT0sqsVQpz3It.99
Ford blamed it on "rainy conditions" which has turned out to be pure BS as it occurs in all climates.
Hydro lock is destructive in any internal combustion engine:
Hydrolock Explained
If an engine’s piston cannot complete its full travel cycle -- up to its minimum at the top of its stroke, then down to its maximum at the bottom of its stroke -- the engine cannot turn over. If the piston or pistons that cannot complete their travel cycle are prevented from doing so by a liquid above them, they slam to a halt on the upstroke, hence the “lock” in hydrolock. This condition occurs when fluid enters the top of the cylinder, rather than gas; gas is compressible and the piston can keep moving upward as it compresses, while fluid is not compressible and prevents the piston from reaching the top of its stroke. Water was called “hydro” in ancient Greek, hence the “hydro” in hydrolock.
Causes of Hydrolock
Outside water can enter the engine through the air intake if the vehicle is driven through a flood; vehicles designed with low-mounted air intakes can draw in water from a bow-wave caused by driving through relatively shallow standing water. Engine coolant can enter the cylinders when a head gasket blows. A failure in the carburetor or injector mechanisms can introduce liquid gasoline where only a vapor-air mixture should be.
Sponsored Links
Powerpoint Into Video
Download Videos To Your Desktop & Convert To Any Format - All Free!
www.videodownloadconverter.com
What Gets Damaged
Although an engine that hydrolocks at idle may simply stop, catastrophic engine failure is likely if an engine hydrolocks while running at speed. The most common result of hydrolock at speed is that the piston rods are deformed; they bend and fold between the piston at their top, which cannot travel upward any farther, and the crankshaft at their base, which continues to travel upward. Absorbing the force of the sudden stop may crack the block, crack the crankcase, destroy the head and shatter the bearings.
Manifestations and Rectification
Typically, an engine will seize solid if it hydrolocks at speed. If only one piston hydrolocks and the engine continues to move, there will be a loud screeching noise. Given that most of the major internal components have been destroyed, replacing the engine is typically more cost-effective than rebuilding.
If an engine hydrolocks at idle, it may simply stop and refuse to turn on the starter motor. There may well be no internal component damage. Rectification is by removing the spark plugs or injectors then turning the engine on the starter motor; this will expel the liquid from the cylinder or cylinders. Once reassembled, the engine should start as normal. The hydrolock, however, was a symptom, not a cause. If the liquid was introduced to the cylinder through a failed component, typically the head gasket, this must be diagnosed and rectified. Further, water is corrosive to the internals of an engine. If water has been inside a standing engine for any length of time, it could have caused rust bands to form inside the cylinder. These would have to be addressed, and the pistons perhaps replaced.
Read more : http://www.ehow.com/info_12177155_gets-damaged-engine-hydrolock.html
So, since in every case to date this liquid mix has been present in the intercooler, charge pipes, and intake manifold (for the shops that have inspected them to see), there cannot be anything else causing these failures as we have yet to see detonation evidence on a single damaged piston, and the point of breakage on every one in the pictures here, that we have examined first hand, and the other dealer techs we have talked to are all breaking in the same areas....which is a sure indication of hydro-lock, especially when several have also had bent rods:
It takes allot of force to bend a rod....and if it was detonation we would be seeing erosion and pitting of the piston tops as is common with detonation.
Open for other ideas, but have been doing this for over 41 years, and see every type of engine failure possible and with some close study we can usually determine what caused a failure as the clues are usually right there.
Give me more of your thoughts on what else can be causing this. We boost the 3.6 DI engines to 500-600 HP and the pistons hold up fine until we exceed 600, and then the rods/rod bolts are what fails first. I really need more input from other tearing these down and make sure they are actually removing the intercoolers, or at least inspecting them internally with a boroscope.
Thanks!
#103 ·
My experience is from an engineering standpoint as opposed to a "hands on" aspect like yours is, and while living in "CAD land" gives an engineer a very short sighted view of the world, I have enough field experience to try and counter that shortcoming (nor do I have 41 years worth!! I'm a baby by comparison!). That said, I have some failure analysis/cfd/fea under my belt and agree that yes we're seeing failures and yes hydro-lock is the major symptom, but the exact cause isn't so easy or we'd know by now.
Having spoken to one of my contacts inside, GM isn't seeing similar failure rates in Regals or Malibus to those of the CTS or ATS. Some have failed, yes, but not in this magnitude, and that has me even more concerned. Could that be due to differences in programming or driving style? Don't know. Look at the old Northstar - if you drove it like a little old lady it'd gunk itself up and it needed to be beaten on a little bit to keep it running right. So it's not like "driving an engine hard kills it" as sometimes the opposite is true.
My dealer has seen a LOT of LTGs fail - and yet others here on the forums have said their dealer has never heard of the problem. Does this play into the potential of geographic location and climate playing a part? I think it has potential but if climate was such a major issue then seasons would also play a major factor and so far that hasn't appeared to be the case.
I've spoken to the techs at my dealer and have shared the idea of fluid buildup inside the intercooler and hydro-lock - and so far of the LTGs that have failed, not all of them have had pooling in the intercooler or signs of it (some have been really clean), and some of the ATSs that my dealer has pulled apart have seen engines failed due to excessive detonation alone. One particular vehicle had clear signs of detonation on one piston while another had a blown ringland - the tech agreed that fluid may be a major player, but why it isn't consistent across the whole fleet is unknown.
With 10k on the odometer my intercooler was dry and the intake plumbing was clean. Now with 16k we'll see if that's changed as it's at the dealer for a leakdown test tomorrow and if anything is wrong they're going to let me go in there when they pull it apart and take pictures. I'm bringing my bore scope to make sure I take pictures with it (just because its unfair to ask the techs to be an engineer).
The oil squirters don't cause a failure - but if you model a piston dynamically during startup with and without an oil squirter on it, you do get minute variations in the rate of expansion across the piston. Do I think it's encouraging problems? When every piston failure on the ATS my dealer has seen has been in the exact same place on the piston (which screams design flaw to me) I tend to think the squirter is playing a part along with the physical geometry of the piston.
I'd wager that there really aren't that many variances on the engine assembly line at the Tonawanda plant where the LTG is built, and I'd also wager that the component manufacturers aren't to blame - I suspect the design changes from the LNF to the LTG included too many attempts to cut cost and in this process have opened the engine up to other problems. These problems aren't outwardly fatal but are agitated by variations in fuel, climate and driving conditions (how it's driven in terms of how hard its driven and whether its 'short cycled' or allowed to warm up at idle and/or transition to closed loop) and manifest themselves in several ways. My car in winter never gets to temperature unless I go on trips on the weekend (commute to work is only 4 miles and grocery store is half mile away) so my car should be on an extreme edge - never getting to temperature is typically horrible for an engine - and yet - after two winters the insides were clean and dry.
Failure statistics are closely guarded because by manufacturers. I've been trying to get some pried out of GM on the LTG in greater detail, but it's been tough. I've been given generalizations and overall impressions, but not hard numbers.
We just don't have enough data yet and I'm not allowed to prowl GM Powertrain and question employees freely. :)
#105 ·
The pictures I've seen online to date don't really show strong evidence of detonation. The plugs too look clean too. It looks like ring butting or hydrolock to me. (Hydrolock looking more common as you don't generally bend a rod from detonation and ringland failure alone unless the piston disintegrates and lodges sideways in the cylinder :)
#107 ·
Thought I would share what's going on with my ATS and my findings, hoping this info helps towards a solution to these piston failures ... For the last three weeks I've been dealing with some bad misfires under boost along with a lack of power from 4k rpm up to redline. I installed new MSD plugs and most of the misfire's went away but there's still some bucking at times while accelerating and lack of power in that same upper rpm range. Feels like timing or boost is getting pulled out but no audible detonation. I don't have a borescope but did pull the charge hoses off the intercooler today and swiped a rag inside and pulled out some real black, jelled oil deposits. I DON'T THINK THIS SUBSTANCE WILL COMPRESS TO WELL!!. I did a compression test and I'm at 125psi across the board. I don't think it's hurt(yet) but I gotta get to the dealer -- real soon. What made GM think they could run blow-by gunk through the intercooler??
#110 ·
Leakdown report from my dealer:
Leakdown Report said:
PERFORM LEAKAGE TEST ON ALL CYLINDERS:
CYL 1 18% @ 15PSI. COMPRESSION 120-180 LBS
CYL 2 19%. COMP 120-180 LBS
CYL 3 20%. COMP 120-180 LBS
CYL 4 18%. COMPRESSION 120-180 LBS
REPAIRS COMPLETED
According to the service writer, GM's cutoff threshold for rebuilding the LTG engine is 28% during a leak down and/or a compression test result under 100psi. Could someone with dealer connections please look up the service recommendation for a leak down test direct from GM? I'm hesitant to believe 28% as the cutoff - that's absurd. 20% is excessive for a car with 16,000 miles on the clock. No. Question.
If that's true, the manufacturing tolerances on the LTG are so freaking poor no wonder why they're nuking left and right...
#112 ·
After so many engines going gm decided to issue bulletin 14591 piston damage due to engine misfire. (9100970 0.8) Replace spark plugs and reprogram electronic control module (ECM) with SPS I already have my new engine but I figured to call the dealer and ask them he said this bulletin came out few days ago they want me to bring the car in
#113 ·
