Anyone get new pistons/engine outside of warranty??? I'm at 80k miles.
Long story short I was in a small accident where I rear ended someone at about 15 mph on rush hour traffic. About a month later after getting the car back I get warning message that the A/C Compressor is shutting off due to potential overheating. I look at my temp gauge and it't about two marks away from the overheating red marks. I got it off the road quickly, my reservoir was bone dry and I could see coolant sprayed on the engine. Found a small crack in the tube going to the reservoir, did a quick repair, all was good for about a day. While driving I smelled coolant and saw that my temps were rising again. Found that my repair didn't hold, and repaired it much better the second time. Started the car and drove it around with no leaks to be found.
In the morning I start the car and find that I'm getting smoke coming from the turbo area, stabilitrak, traction control, and check engine lights are on, as well as rough idle. So I drive to Cadillac which is about 1 mile down the road. During driving it felt fine but at stop lights it idled terribly so I shut if of when I had to wait. Pulling into the dealership and driving through the lot at low rpms I find a huge hesitation in the pedal and loss of power. And gain I could smell coolant. When I parked and checked under the hood half my coolant reservoir was empty with NO signs of leaks outside of the engine... But looking at the oil I didn't find any discoloration or milky residue...
I had the spark plug and ECM update when it came out. My warning light symptoms and bad idle sound like I have a bad piston, but would that explain where my coolant is disappearing too? Not sure if my potential overheating caused the bad piston symptoms to happen or if the two are happening coincidentally...
