1 - 9 of 9 Posts
None
Does anyone know of a direct test comparing the 2.0 and 3.6 rwd cts's performance properties. I've only seen brief mentions of the two cars small difference in 0-60 and mpg but I would love to see a more elaborate comparison!
I think the performance between them are pretty close, if not identical. I know I tested both before buying and thought the 2.0T actually felt a little faster. Certainly, it has more torque off the line.
2007 CTS
and check motor trend and Edmunds for reviews. The 3.6L doesn't have enough torque so the performance is is about the same as the 2.0T. Cadillac shouldn't even offer the 3.6L. Use the 3.6L twin turbo instead and turn it down to 330HP/330 ft lbs of torque.
Prev: 2018 ATS 2.0T NOW: 2020 CT4-V JR
Motor Trend COTY issue said that the 2.0T AWD was faster 0-60
than the 3.6 RWD, by .3 sec. It also said CTS4 2.0 was the same
0-30 as the Twin Turbo.
One car of each model, doesn't mean each car is running the
best it can or one could be broken in or have better gas.
14 CTS 2.0T, (traded 08 CTS 3.6)
Another difference you'll see in some of the tests is that the lighter weight of the 2.0T benefits handling. The 3.6 sounds better, doesn't require premium, and is stronger at high speeds. The 2.0T is lighter, stronger around town, and may get better MPG.
2014 Cadillac CTS 2.0t
I have the 2.0t awd, love it, I did some 0-60 tests, I got somewhere between 5.6-6.0 seconds, I love the 300 torque it takes off really fast!
2015 CTS4 3.6 luxury red obsession with cashmere
I had a 2.0T ATS and now have a 3.6 CTS. The 3.6 isn't as quick feeling, but I love the sound of it. That 2.0 sounded a little whiney sometimes to me. The 3.6 is very nice for cruising. The 2.0 was more fun in the city.
1 - 9 of 9 Posts
