1999 Seville Sts
Seville goes into gear but doesn't move sometimes it will show in low gear when in Park please can use any advice thanks
Check the shift cable attachment at the quadrant on top of the transmission - engine compartment right at the firewall about where your gas pedal toes would point. A ball socket.
If it's not that then it's probably an internal transmission fault.
Not sure if the 1999 4T80E had an Internal Mode Switch on the valve body - that's correct model year service manual info. www.alldatadiy.com.
Have you checked the trans fluid level?
I havea 1999 Cadillac Seville sts recently the car stopped moving forward and showing a code P1520 park / neutral switch circuit.and displays 2gear on the dashboard i replaced park neutral switch and the code still appear and the car did worked normally for about ten minutes please help what's wrong
Welcome to CF !!! I changed your thread title to be a bit more descriptive of your problems. Your two threads on transmission problems have been merged into one.
Use this to decipher trouble codes and post then and their definitions.
