1999 Fleetwood Limited
1999 DeVille Heater-A/C will not go in "Auto" mode. Stays in "ECON"
I noticed that my HVAC system will not switch into the "Auto" mode (stays in the "ECON" setting) on heat or A/C. I thought I saw a message on the dash message thing that the A/C refrigerant was low but it has not come back on and it is still in ECON. If I run the front defrosters the ECON will go off.
Thanks for any input.
· Super Moderator
2010 DTS
Re: 1999 DeVille Heater-A/C will not go in "Auto" mode. Stays in "ECON"
And you are going to have to clear the low refrigerant code in order to enable the compressor before you add refrigerant (assuming you do it yourself).
· Master of the Dark Art of Diagnostics
check for Diagnostic Trouble Codes -
if you don't know how - go here and read the ENTIRE post -
http://www.cadillacforums.com/forum...ncluding-1985/138257-how-pull-codes-dtcs.html
if you have any codes - post them here -
ALONG WITH THEIR DEFINITIONS -
we expect to see a LOW REFRIGERANT code
