1 - 16 of 16 Posts
1999 Cadillac Catera
Fog lights used to turn on now they don't anymore. Sometimes they had a delay. Now they just don't turn on. I press the button and the light on dash doesn't d
Come on neither do the fog lights
2000 Catera Sport
Replaced yo. I got me one from junk yard. And its work just fine. There is a thead here on forum. SEARCH!!!!!
Discussion Starter #11
So this morning I started car and fog lights turned on. It was raining maybe some water go on switch when I left car door cracked to go get in trunk for something. Just like the other day spraying and cleaning inside of car....or whatelse cold it be? Is the relay switch in the in the fuse box under the driver dash? Or should I get new switch? Price checks? Thank you. If any one can get back to me sooner my number is 717-342-9461
Discussion Starter #14
Fog lights come on and off when they want to... Is it the relay switch? Brown one? Has like 5 prongs? Thank you.
cadillac catera
Well i can tell from personal experience, that when i had to fix my fog lights for it to pass inspection i was laying on my back for a week trying to figure out what was wrong with it. In my case you should check underneath the fog lights, there are rubber boots that cover the opening for the fog lights ing case you need to change the bulb. What happened with mine was that water or something got into my driver side fog light housing and corroded the metal on the inside, so while my fog light was getting the positive concoction, the grounding for the light bulb was corroded so the mean't that the it was not making a complete circuit in order for it to work. So my suggestion would to be check the housing of the fogs lights and make sure the connections are all connected or making full contact and check for corrosion on the metal grounding plates or wires.
1 - 16 of 16 Posts
