On December 15, 2007, I paid for a Head Gasket repair, bolts drilled out and Heli-bolts added and an engine reseal at my local Cadillac dealership. On December 26, 2008, the engine overheated and I was told by a different mechanic that the HG had blown again. (NOTE: The digital display never stated "Engine Overheated" - when I realized the car was getting hot I put it in Neutral and shut off the engine before the thermo hit the red). The mechanic is someone my family has trusted with other GM cars for 30 years. I had used him for oil/lube/filter due to the convenience of his location, but generally relied on the dealership. The car was serviced five times between the original repair and 2nd incident (3 times at the dealership / 2 times @ mechanic - a total of 12,000 miles were completed between the dates mentioned) The mechanic is close to my home, and so was the incident, so it was towed to him (the dealership is 25 miles from where it happened).
The mechanic identified that the HG failure was on the coolant side, and not the oil side, and thus, when running the exhaust drips water and pale exhaust from the muffler.
All this said to ask three simple questions (but supply you, the experts, with the details):
1. Will K & W Block Seal successfully "bandage" the problem, and possibly provide me with additional miles of enjoyment? I will not spend another $3500 on the car, so it is off to the graveyard if this is not an option.
2. Has ANYONE had success with the K&W product on their Caddy?
3. Where is the radiator drain seal? I've read thru hundreds of posts of other models, but haven't found one that addresses my model (not the ETC).
I enjoy the car and do not mind continued service at the dealership (my wife works near it now, so servicing it is convenient).
