Yesterday I had code c1243 which caused 3 lights on the display...
1)service stability system
2)abs
3) traction control
My mechanic removed /cleaned the connectors and fixed a bad ground on the ABS pump for c1243 per manual and all lights were off for about an hour. Now it has c1243,c1234 and c1255 !!!! I dont care if the thing burns to the ground I'm not banging my head trying to fix it and clear the codes as the brakes work fine...i just want to get the lights off the instrument panel so Im not reminded everytime I drive it . Can I pull a fuse or something to make them go away? I realize this will disable ABS put Im sick of throwing $$$ at this thing right now.
2)abs
3) traction control
