Can anyone explain to me how to remove my headlight switch. The switch is a complete assembly that has the push/pull switch, the twilight slider, as well as the trunk and gas release buttons. Thank You in advance.
IF the end panel on the dash pulls off you can reach in and push the switch assembly out of the soft dash material. otherwise, you carefully pull/pry it out.
I baught a 1999 cadillac devill show car I had it for 6 months now I have oil in the water I love my car the old owner did not mention to me any thing about the problems with the 99 I would like to replace the engine with some other kind of engine but not sure what engine would fit in my car can...
I am getting little to no heat on the drivers side, passenger side is good. How do I know if the actuator is bad or the blend door itself? I can go from hot to cold and back on the passenger side, obviously not the drivers side. I can hear something moving back there when you raise and lower the...
I have a 2003 Cadillac Deville that I was told needs a new head gasket. The car only has around 68,000 miles on it. I put new tires and got brakes and tie rods and alignments done. I am located in Apple Valley MN and would like to find a place that would fix my car. Close by would be preferable...
(Moderator EDIT: Thread moved from Tech Tips to the correct Deville forum. Welcome to CF !!!. Sub.)
Hello,
I'm making a post here to ask if anyone has experience fixing this issue. Whenever I try to crank up my car it doesn't start but sounds like it's but to turnover but something stops it...
